pompeo79
I have a doubt.
After placing views in a panel of a part (e.g. a bearing), I insert a text and I want this text connected for example to the physical properties of the model (e.g. the mass), inserts the parameter <mass>, which will update with the mass of the bearing model.
It's all right.
but, if inside the same table I inserted another basic view of another part (example a tree), and also of this I wanted a dynamic writing connected to the mass of the tree... it is clear that I would have problems. since the script <mass> , if I insert it.(even by selecting the "shaft" pattern in the text dialog box). will mark the bearing mass.
there is no solution..in the sense that the properties of the model in the texts can refer only to a model... or how could I do to have two dynamic masses for two models in the same table?
Thank you!</mass></mass>
I have a doubt.
It's all right.
