cacciatorino
I have a little difficulty.
If I change a style of wrinkle or for example a geometric tolerance, more generally a annotation on a template, I find that modification only on the template on which I made it, for example a4.drwdot or as it is called, so if I start a new table with the a3.drwdot I don't find these changes. I have seen that I can save these symbols in the library, but then every time I make a new design I have to recharge them in the current design to be able to apply them. would it be possible to make sure that the modification made to a style-level template automatically propanes to all other templates? so that every time I open a new design I find everything loaded independently of the chosen format?
with the other cad that I use in reality the template is unique and inside contains all the backgrounds (a0, a1, etc) and from the menu select the one to be applied to the table in object and to be displayed on screen and in print (clearly at the cost of having the drawings a little more 'timber because then everyone takes behind all the formats), for which this propagation is automatic and transparent to the user. would it also be possible in swx to have a single template without all these drwdot and sldrt in which I am sincerely losing myself?
I understand that the subject has been treated n-mila times but being a beginner hard to understand and I wanted to take a step ahead of where I arrived now.
