cacciatorino
some questions about the lines fonts:
1) orthogonal views:
is it possible to set swx in such a way that it is inhibited by default by displaying tangent edges on orthogonal views? Now it shows me in a big line and I feel worse about the readability of the design, so I always have to go hide them by hand after generating the view with the command "remove tangent edges".
2) assonometric views:
is it possible to set swx in such a way that the display of tangent edges is made with the tangent edge? Now even if I set the thin line in the fonts to assign to the tangent edge, it always makes me see it in big line and I have to change it manually.
is it possible to set swx in such a way that the hidden lines are removed by default in the assonometric views (but must they remain visible by default in the orthogonal ones)?
3) sketches at the table
If I have to add lines at the table, I use the sketch tool. The problem is that all the added lines are continuous thin. also setting the sketch font on the dotted line or axis, the preview of the generation of the primitives is correct (it is displayed with the chosen font) but then when confirming it returns in thin line, and the thing is also printed in this way.
