table with "variant" views
  • Thread starter Thread starter kitelakes
kitelakes
Good morning, I diligently sought in previous discussions on the theme variants but I did not find something to solve the problem.
I would like to compose a table with the view of (example) a plant of a building with tables, and with another view where you see the same plant in variant, with different tables.
apparently this would not be possible (it seems unlikely therefore I forget something), as if in the first sight I have "main model", in the second view (same table), I cannot activate the "variant" as it would disappear even in the "1° view"
What is wrong/forgettable?
2nd question but can lines be inserted into the "variant"?
because these if "I keep the variant" and active the main model does not disappear. .
thanks in advance
You know I don't understand. . .
detail lines or pattern lines?
in a table I would like to put 2 views of the same plan of project with different internal panels (I am making an example).
How do I use the variants system?
If I turn on "the main" in a view, in the other I cannot turn on the "secondary"... or at least this is what happens to me
twice duplicate the view.
then in graphical visibility activates the variants tab.you will find the automatic setting, means that by default it associates with the view the main variant. ..you just need to click inside the field and select the name of the variant you want to associate with the view.
repeat the procedure with the other copy assigning the second variant and the game is done.
ps the same applies also to the abachi.. .
It was what I was looking for, thank you very much:)
