table
  • Thread starter Thread starter franc.franc
franc.franc
I need a tip regarding the sw table (version 2007).
I'm creating a custom table but I can't create links to make that material, scale, and descriptions fit automatically.
I explain: for example for the name of the particular there is default $prp:"sw-file name". This way it goes to take the name of the saved file....
I don't know where you go fishing these links.
Thank you all.
Hello, Frank.
If I didn't understand, you need a distinct model of materials. If so is the most practical method to create one is:
1- create a support set, with at least one part inside. this part must have all the custom properties that will serve in the distinct.
2- create a design of the previously prepared axieme
3- insert a distinct material, it is also good that standard solidworks
4- format the distinct as you want it as number of columns, column width, etc....
5- assign properties to columns. to double-click it on the gray area above the column to change select the property name from the combo.
after completing the separate click it with the dx button, choose save by name and save the file to get a pattern to reuse.
..think refers to the automatic compilation of the cartilage at the table.
if so it is simple but a little long to write ( easier to make than to say:biggrin:)... now I am running.
even if I no longer use 2007 for a while the procedure is always that.
Mar
Hello, thank you for the answers!
I actually meant the compilation of the cartilage, even if the tips of the distinct material serve me equally.
Hi:
