tabled by a group
  • Thread starter Thread starter roccolaser
roccolaser
Hello to all the boys, I begin by thanking everyone for the help you give me, I had another problem if I have a set and I have to make a Mass on the table I can behave like if he had a part? because I tried to put it on the table but I can't select the bodies as I do with the part which procedure I have to adopt? :confused:
if the axieme is composed of parts you must insert into the table that interests the various parts that make up the axieme or is a multibodi and then you inserted it into a set to put the vice?
you have not attached the assist cmponents therefore difficult to give you better directions, so either pack&go or try to be clearer.
Meanwhile you have to attach the part too otherwise you only see the screws.
What exactly do you have to do? in the table of a set you behave like in that of part then sections, details, auxiliary views and so on); However, the table of a group is born with a different purpose than that of part. in the first from information regarding assembly, in the second from information for construction.
I would therefore say to the eye that in this case you will have to have a constructive table of the ring with its handkerchiefs, then a mounting table in which you will indicate the reference of the ring (drawing, code, name or what you use in the distinct), the screw and any other information.
Do a blessed tutorial because you're trying to swim with the swollen armrests.
Of course those of solidworks!! !
a set consists of parts that have a precise lease address of the computer.
if your set is in the folder machine machine and the part in the folder component is in the latter that solidworks will go to look for the part contained in the axieme. if you move without correct systems the part in the folder honolulu solidworks does not spy on you and does not know that it has to go looking for the part file in another folder; will always look under component and not finding it will invite you to drink a coffee and try again.
you attach the assist and the part you hold it in your pc, what can we see according to you?
but then explain what you want to get... in a drawing board you can put in what you want, but according to what you insert you will have certain possibilities.
insert a set- you can livelise it until you release the jacobble saint, but you will always confront each other with parts that are made in multibody or not and therefore will be unique elements.
insert a part - it is one and three and you can extract all the individual bodies.
if you want you can enter the same table both together and part, but the views you enter will have to refer to .sldasm and .sldprt file
I try... go....
torque must "simplely" insert a body of a part contained in the design view of a set.
has two roads to be able to walk (in reality there would be other ways, but I do not want to confuse it further):
1) select the part file from which to extrapolate the body (first part of the attached video).
2) select directly from the tree the object from which to extrapolate the body (according to the attached video)
(video available shortly)[youtube]awwpr7yp6-u[/youtube]
you need to use display states and/or configurations.
you can also choose to insert bolts directly into the part.
However, I urge you to clearly expose your requests for help.
I'm sending you the bank of my bank account, I deserve a salary, too.
but if you already have a set with part and bolts, why do these pindaric flights?
a detail, a section, a trimmed view and get the result without too many patemi.
