tables
  • Thread starter Thread starter giocamb
giocamb
hello to all
I wanted to ask you if you ever created a table in the table of points.
I created it but it does not put the points in order.
I'll explain. the points on the model are named pnt001 -pnt002 etc.
table insert pnt001 - pnt010 and not in pnt001-002-003 order
someone can tell me if there is a configuration in config.pro or in .dtl to put the points in order.
If the table is a repetition region I think you just order it according to the parameter you like, for example the name, or one of its coordinates.
table... regions repetiz... ord region... (Select the repetition region) add.. .
growing / decreasing... (check the desired parameter)
hoping to have been of help
aminati
