cugior
Hello my name is alessandro work in a shipyard.
Currently, despite not really my work, I am devoting myself to the sizing of a transmission shaft of the fire pump of our floating basin.
since I am a little rusty on these calculations I allowed myself to ask for your opinion on some details.
as the axis is about 8 m long I have the need to make joints (mancions) that transmit motion through tabs.
- note the torque, the diameter of the tree, the material of the tab, the section of the tab (table), how do you calculate the length? is it correct to obtain the minimum area of the tongue subject to cut due to the torque effect simply as a = f/tao, where f is the circumferential force that I echo from the couple and tao the tangential tension that I echo, through the criterion of mises, from the yielding sigma?
- if a joint consists of a cylindrical hub that presents the groove for the housing of the two keystrokes, how do I dimension the thickness of the hub?
I hope you can help me because I've been working for 3 days and I couldn't find anything about it.
thanks and soon
thanks and soon
