Are you telling me I have to write it from time to time?you have two options: either on your custom signatures I write it directly or there is a variable that I don't remember anymore....that you can add as the property of the table....but of course you see it in the folder and not in the file name ... clearly.
must be a property of the table model a4...a3.....Are you telling me I have to write it from time to time?
what I noticed is that above I see the name of the table followed by the sheet name. So if I give him the name es a4 on the sheet above I see what I just want. I just have to do it by hand while I want him to do it.must be a property of the table model a4...a3.....
handwritten or inserted as a variable. Clearly if you save the sheet template with paper stamp, you will find it already written....but on the chart and not on the file name.
