Ngiolett
Now I understand, another question I don't have the same problem where the right rump is?how to change the conical part
you can omit it if you do the detachment as I have indicated otherwise if you do everything attached the tolerance is unreliable to have a functional locking.the professor told us that in this exercise we can omit that tolerance
Now that you raise this question you make me think that maybe with advising you the spacing I said a cow... I have to think about it better. definitely missing something that drags the tree to the wheel of the pulley, so I would say you have to insert a stick on the conical part and respective seat on the wheelNow I understand, another question I don't have the same problem where the right rump is?
If rectified, a wrinkle may be fine, 0.8.Right, I put a roughness of 0.4.
applying a mating with interference I get a force and consequently I go to transmit the pulley wheel to the tree. Why should I insert a key?Now that you raise this question you make me think that maybe with advising you the spacing I said a cow... I have to think about it better. definitely missing something that drags the tree to the wheel of the pulley, so I would say you have to insert a stick on the conical part and respective seat on the wheel
apart from that on a conical part you can not mate with interference because for their shape the surfaces slip up to contact and not beyond; the locking takes place through pressure between the surfaces given by the locking of the nut.applying a mating with interference I get a force and consequently I go to transmit the pulley wheel to the tree
I thank you for the amendments to the aid tomorrow.in this page the explanation of conical mounting with nut.
Note that a threaded wreath is used with safety rosette and not a simple nut with rosette.
on the left is inserted a spacer that allows to be adapted and therefore guarantee contact between the conical parts
