template e workset!
  • Thread starter Thread starter aj89
aj89
Hello everyone!
My company asked me to produce a custom template as they work with projects very similar to each other!
the company works with worksets and I read that templates do not support worksets.
Is there a way to solve this problem, or an alternative?
Thank you!
you can not use a ".rte" file (template) with worksets, but you can use a ".rvt" file with worksets, if before using it, you separated the file of the central. later, you do "save as..." as the new central file of the new project. not and the commune, however, would protect itself.
