tensions in material
  • Thread starter Thread starter vale79
vale79
Sorry if I've already put a post in another section but I haven't solved my doubt yet, I hope someone can help me. There should be a formula to calculate how much material I can remove from the inside of a round profile, full, without creating excessive stress to the material. Do you know anything?
Thank you so much!
That's right.
If I didn't misunderstand, you're referring to pressure cylinder theory: the maximum eq stress state is on the inner wall... there are formulas. it is best to consult the complete treatment from some mechanical design book.
If you can repeat the question about what you are looking for exactly, maybe I could answer. Hi.
Bye!
the theory of pressure cylinders could be a start but my pieces are not exactly cylinders, gift cylinders worked obtained for turning and have openings on cylindrical faces. I don't know how clear it can be as an explanation, I'm working on the components of thermostatic cartridges for taps: body, shutter, etc.
Thank you very much
That's right.
