test bench doubts and suggestions [tesi]
  • Thread starter Thread starter MrKero
MrKero
Hello to all guys, today looking for information on the network I found this beautiful forum, I look forward to exploring it better
The problem is that I should soon graduate and finish the thesis for three years
I'll put it right away.
being a thesis for the three-year degree everything is theoretically, I would like to create a test bench that functions in an inertial manner, so with the mass connected to the tree and/or with the brake, my doubts are
1) If I only use the parasite current brake it is then possible to detect the pair without blocking to a certain number of turns the brake?
2) Always using the parasite current brake, should I use an inertial mass? how do I calculate its weight knowing only the power in play which is about 17 cv
3) if I decide to do everything through inertial mass, always remains the problem of tracing the inertial mass, and if I want to connect the brake to calculate the cup curve for fixed points instead of the maximum one, the mass should be lower?
I hope you can help me!
Thank you!
I see no one can give me an answer
you know at least some builder of test benches at parasite currents that are not villages and savers that have practically nothing on their site!
ciao,
It is possible, at each regime corresponds a braking couple regulated by the brake.
Thank you!
What does that mean? What do you mean by inertial mass?
