text checkbox
  • Thread starter Thread starter ginosapone
ginosapone
Good evening, everyone.
I have this problem:
in the autocad lt 2006 menu bar I entered a text check box, so you can easily change the various text styles with the handy pop-up menu.
I expect that, after selecting a text (which is normal or multiline) and selecting the style from the above box, the text itself changes, according to the new text style. That doesn't happen.
in autocad 2008 the same procedure works great.
I think there's a problem with variable settings. . .
I also tried with autocad lt 2008 and the procedure works.
that is something introduced with 2008?
I never used lt so the case is difficult to play, but actually I never used the pop-up you say to change a style, I thought it only worked to set the current style. instead I saw that it adorns the selected entity. obviously to do this you must select the object first and then perform the change.
in lt I am not sure there is, but the same operations (and others) the controls directly from the property window (_properties or ctrl+1) where always from drop-down menu perform the same changes.
p.s. if you want to join the group http://www.cad3d.it/forum1/group.php?groupid=2bath
in autocad lt 2008 works.
I knew about the property window. but I wanted not to use that.
other thing: is there the possibility to "export" all system variables of a design, perhaps in a text file? There's something to set for me. . .
I ask a stupid question... did you select the text in the box before changing the properties?
in previous versions of autocad, the properties were of the box, now instead they are the property of the text, then you have to select it, otherwise it does not work
according to me the only variable that could somehow affect this behavior is the name/verb selection since you must first select and then run a command
_pickfirst must be set to 1
check whether the selection of objects is made before (select name-verb) or after the issue of a command.
0
turn off pickfirst; the selection of objects is carried out after the start of a command.
1
active pickfirst; the selection of objects is made before the start of a command.
However, with the modvar command, you can see a complete list of all system variables. ctrl+c copi e ctrl+v incolli in a text editor or if you have a full and express installed _.sysvdlg
cmq do your tests however it can very well be that it was implemented even after 2006 this option.
Thanks for the answers.
@fulvio Roman
by selecting the text in the text box and then selecting the new style in the pop-up menu, then you will quit. But that's not what I wanted.
@shape
Pickfirst is not the correct variable.
I don't want to waste time anyway. for me is something implemented since 2007 onwards.
in any case, if they select a quota and change the text style from the menu that I want, all as I would like.. .
