text on panel
  • Thread starter Thread starter Bredley
Bredley
Good evening, everyone.
I'm circulating in a problem that I don't know how much a problem is (for you).
.... then a text will be cut on a panel.
....I create my beautiful text, and here comes the problem that in some letters like b la or la to the inside does not remain attached.
There is a way to get the empty part attached to the full part.
I explain myself better I do the or, it is cut the or and the inner part of the or remains free, it does not have where to attack, instead of going mad with sketches as I can do to keep the inside of or to the outside.
the text must be that I cannot change font
work in part mode and use the wf2 thanks to all.
I hope I've been clear.
thanks to all
The only way is to make small extrusions that connect the outside inside I see no alternative. . Anyway the problem you would have with any program if you do before maybe export the dxf and do it with autocad
Thank you for your answer.
the only way you told me is the only one I knew and I wanted to avoid, cmq in any way I already armed myself with patience.
alessandro
