there is a pivot/hole component positioning command
  • Thread starter Thread starter Giancesa
Giancesa
I don't know if sw has a positioning command touching two turns, one of a screw, one of the hole, automatically positioning the screw to its hole. for this now I do so: first I give concentricity and then I support the underhead of the screw on the plane of the piece. I wonder why inventor had it and it was convenient. Thank you.
I tried by clicking the two edges, but you also need to click "center profile". the thing speeds up by clicking directly "centre profile" when opening the quick menu
If you select the two edges and give only the coincidence in basic materials?
cmq after years of assembly of this type (piping) in the end I decided that it is better to give the classic 3 couplings, concentric, with accident, and parallel to avoid rotation (or to the maximum block rotation, that in 2020 is comfortable and appears just after giving concentricity)
Unfortunately the same command is not there, but you can do this:
- hold the alt key
- click left and hold the underhead edge of the screw
- drag the screw and approach the edge of the hole, at this point should "capture you" the point
- release everything and create the two constraints
Mature
you must define mating rules in the screw (or pin). open the screw, select the circular edge lying on the plane that must go into contact (subhead) and then go on "put->geometria reference->regole coupling. confirm and save the component. Now when you insert it, just touch a circular edge, it is concentric and coincident position. If it is oriented to the reverse, you can turn it with the tab button during positioning.
Let me know if the result is what you meant.
