Salocs
Hi guys, I would like to set the heat contact between two bodies and then perform a transitory analysis in ansys apdl..I have small doubts: in practice with the contact pair command select the two contact lines, then the program obviously asks me the termal contact conductance. . .Being the two bodies one in steel and the other in aluminum in how do I interpret it?? ? Should I insert an average value between the two?? Thank you!:smile:
