davide_r
excellent method for the packaging of mechanical parts subject to oxidation without using oils or protective coatings.
the principle of operation of the thermoreduction is very simple since it is based on the properties of the polymers (in our case polyethylene or polyolefin) to retire if subjected to heating thus assuming the shape of the contained object but maintaining its visibility thanks to the high transparency of the material. the product is packaged by an automatic welding bar machine teflonata and then passes through a tunnel with berries oven that heats the film causing it to retire and thus assuming the shape of the product. with this system can thus be protected particulars built with machining centers and machine tools, moulds for plastics and die casting, plates, materials and minuteries in cardboard boxes or plastic material, profiled and semi-finished alloy in addition to an innumerable amount of objects of each form, material and size.
t packaging offers different types of programmable and usable angular automatic packaging machines for products of varying nature and size that, in some models, can also reach appreciable heights and infinite length. These are machines with extremely simple and intuitive operation (they are equipped with touch screen control panel) and excellent price quality ratio as well as relatively small size, therefore also suitable for use at small workshops, warehouses or laboratories.
for more information view attached videos or complete catalog with models and technical features, on the site http://daviderigoldi.wordpress.com/prodotti
[video=vimeo;36192179]http://vimeo.com/36192179[/video]
