thick lines in draft environment
cordi
Hello, everyone! :biggrin: I have a problem changing the thickness of lines in the draft environment (both hidden and visible).
using the edge painter command I should change the lines by selecting them one by one but it is too complex for the component I designed.
how can I change the thickness of the default lines? (visible, hidden.)
Thank you in advance! :wink:
p.s. use solid edge st6
you need to set the thicknesses on the template so that they always stay. go to styles and edit how you need to save everything and whenever you create a new design using that template you will have everything set.
