thickness sheet metal sheet metal design
  • Thread starter Thread starter ijk
ijk
Hello everyone, I have a question to ask you.
I am drawing a frame composed of welded elements between them as tubular and plates of various thickness.
I would not like to manage it as a product, so I decided to create a part with many body.
the problem lies in the plates: the parameters of the sheet metal design environment are unfortunately referred to the whole part and not to the individual body, so plates of different thickness can not manage them.
in practice if x plate a (e.g. body4) use e.g. 4mm thickness, I can't create another plate (e.g. body7) using thickness e.g. 3mm.
my request is: is there no way to attribute the parameters of texting to the individual body and not to the whole part?
Do I have to create a product?
thanks for the attention!
Say hi.
catia is production oriented, so 1 part 1 body 1file! so yes, but for your sake, you will put on the table the parts divided by thickness. . .
you can also model the sheet metal files apart and copy them with links in a single part under different body.
or model everything in a part and then at finished work copy the individual body with links in different part files and operate for each sheet converaione. . .
Good job!
