Davide C.
Good morning to all, I have a problem displaying a thread in the table setting of a set. I realized the filetttaura with the appropriate command to have the 3d model including the thread (it is a plastic detail from which they have to make a mold).
the display in the section of the component is correct.
Unfortunately in the section view of the axieme the display is not correct and you see all the edges of the thread even if they are nothing opposite of the section (so not visible).
The default table settings and template are obviously the same.
solid problem or any setting to change on the axieme?
