ragnol
Hello, everyone.
in a niche of discreet size (150xh300cm) will be mounted a wooden panel (artwork) of the weight of about 2.00kn. the panel discharges the weight to the foot, being leaned.
to avoid tipping out (a dumb teenager trying to pull, wind depression etc. :d) will be put 4 brackets (two in low to 80 cm from the foot, two at the top) fixed to the bottom wall using resin ø16 thread bars.
the parade consists of masonry - healthy - in plastered stone, then at the moment of fixing (the position of the anchors is obliged) you can not know if you will drill a stone conical or only the mortar of amorsation.
the various tables (e.g. fischer) give as a minimum seal value ammissibi traction on perforated bricks (the worst support among the tabled ones) for a ø16mm bar about 1.00kn.
you have specific values for stone walls with some table in support (I imagine the question: which stone, how, etc.)? would you use, as I think I do, the values related to perforated bricks and so much greetings?
the body that commissioned the work asks for a handkerchief with indications on the assembly/disassembly procedure and two calculations on the cross on the fixing.. .
