lustro
Hello everyone, I would already need your help.
I did a research but I find nothing that could help me.
the problem is the following: I have a simil-boccola on which I have to make 3 threaded holes, and I have to do them on the outer perimeter, but with the command created hole nn I manage.
first I create the sketch (I tried to do it on the middle floor, then on a tangent, then also on an intermediate...
) to give the positioning, then when I go to create the hole, I always appear the message " points to locate the nn holes are valid. may be bound or may be located on edges or vertices."
the fact is that the points are bound by the necessary quotas and nn are on edges or vertices
instead with the nn extrusion cutting command I have no problem.
he managed solid edge, solid works 08 I thought it best in 3d....
suggestions? ? ? ?
suggestions? ? ? ?
