czar
hi, I have Japanese colleagues who have forwarded a design where a flange has a trunk-conical hole on which they applied a control of the angle with a tilt tolerance, the value of the angle is expressed as theoretically exact size and the plane of reference is the planar surface of the cylindrical flange.
I am not so sure that the inclination can be applied to entities that are not axes or planar surfaces...an axis of a sloped hole compared to a planar surface there is, a surface with a surface also, but I would say a cone (male or female) should be controlled with other types of geomentary tolerance, coaxiality, profile, total oscillation, in theory I should get two equidistant surfaces between them from the theoretical one.
What do you think?
What do you think?
