Mello Dessi
Good morning to all and thank you in advance for those who want to help me.
My problem is this:
I have to make a lifting plan with a moving crane.
of this crane I have everything, dimensions, slender length, maximum flow in the various rays......etc. What I would need is the load on the stabilizers, how many kg is dumping on the ground with that radius and that weight. the crane's arm turning 360 ° and having the non-baricentric raddle center there will be so many exhaust configurations, I would need to know the most critical one, because from that, I will choose the most appropriate redistributers for that type of terrain.
there is already a site where you can calculate this data, but only for some specific models of cranes.
the stabilizers lean on the ground at a distance of 6x6.15 mt, the crane has a weight of (q1)50t + (q2)5t of ballast, and must lift a load of (q3)6.4t, placed at 12.856 mt from the raddle center, the crane arm is set at 20mt.
I do not know if in these cases a safety coefficient must be added.
I tried to schematize the crane in the attached file.
My problem is this:
