Prog_Pie
Hello
I use catia v5 r19 and should carry out an analysis with fluent 6.3,
I wanted to know what the right procedure is to create meshes to impose it in fluent?? ?
Is the catia not able to create mesh and export it and then put it in fluent?? ?
So what do you recommend? ? . ..gambit for mesh??? or tgrid? ?
and then how do I introduce the solid??? with the format igs? ?
I then found the "fluent for catia"... but when I install it, it tells me:
"no catia installation area found"? No... and how do I have the caty r19
will that version be compatible only with r15,16,17? ? ?
then exist versions of caia with incorporated fluent? ? ?
