gregario
I am building a frame of a bicycle, using the solid bodies, but I am at a dead point (unfortunately I have no images to show you what I mean, I try to words...) I built (using the loft function, I have different sections that make up the same element) tube and tube across, as extrusion I built the cylinder of the central movement.
Now the 3 bodies are united between them (in the central movement), but I can't connect between them (function fittings) the three bodies (there are 3 edges of the weed that are in contact with both the central movement and the transverse tube) and the function goes in crasch....
I don't know what to do anymore. .
I hope I've been spiced out... ?
hello and good day
hello and good day
