to create a custom hole table
  • Thread starter Thread starter etc
etc
hi to all, I looked for a little for the whole portal, and found the library of gas holes that I needed; But I wanted to try to understand how to create a table/freeze of holes from me, from start to finish.
I ask your help because I know that, while reading the guide, I miss something.
I do not understand what these parameters are to be inserted, there are no examples, it is all a little too generic.
I am not a mechanical engineer or an advanced pro/e user so I have to arrange as I can. I ask you if you could give me a little help.
doubt:
- in the case of gas holes, observing the unknown edges, (in solidworks you notice) is normal?
- Do I need to create a hole profile sketch to insert it into the table???
- many other doubts:
If however I have well understood, these holes are those then I will see in the list of holes available for the feature holes.
hello and thanks for the attention, I hope to be able to solve this "problem with you".
