together "flexible" zipper
  • Thread starter Thread starter Desmond
Desmond
Good morning, everyone.
I am trying to learn the basics of creo parametric after using for a long time inventor and I have come across a problem probably (very) banal for those who have used it for a while.
I created a joint zipper with the pin bond, with so much lower and higher limits that work without problem when I drag the mobile part.
I've got the problem when I put the zipper in another set. in inventor there is the possibility to make "flexible" the axieme hinge which frees the degree of freedom and allows rotation. I think I understand that "flexibility" in creo is much more complex and I'm not even sure it means the same thing.
Is there a similar function in creo that allows me, through the command drags component to simulate the movement of a door bound to that hinge?
Thank you in advance.
I obviously did something wrong. a set (with degrees of freedom) inserted in a set keeps them naturally.
I thought he reasoned as an inventor, for which the assemblies remained fixed unless they introduced flexibility.
