together of sheets:variate thicknesses
  • Thread starter Thread starter canebao
canebao
if an entire project has been made with sheet metal parts of 1.5 mm thick, changing to all pieces the thicknesses bringing them to 2 mm, according to you I will go to encounter construction errors like uncentered holes, pieces that collide between them...
if there is a solid edge functionality that allows me at least to have highlighted these conflicts?
thanks in advance
always depends on how you built the parts, which reference systems you took for holes etc. I don't think there is a system x find errors for the simple fact that if you have referred to the thickness of the sheet and this has changed and such change does not create conflicts...beh why the system should complain? if there are conflicts in the individual files you will be reported.
or you have to create the pieces with the ties, i.e. enter the axieme, open in
change the piece, enter the profile that must follow the course of the first
go to instruments/individual edge and selections " paritetic elements" so you can
put the profile reports by hearing the other piece of the axieme.
once you change the other will follow him.
to detect collisions, go see on the help the voice collisions so see if
There's something that can suit your case
In the case of aligned holes, if we pass a screw or rivet in the middle, with a simple search for interference already you should highlight a good part.
