Stan9411
Good evening to all
I am here to ask you another question and once again the topic is on tolerances. at the university explained to us that the element interposed between tree and hub (cuscinetto, bronzina ) goes in interference with the component that feels dynamic load and in play with the component that feels static load (classic example: bearing for the shaft of a gearbox --> pins of fixed bearings in space --> play on the frame and interference on the shaft ).
instead it sends me in confusion to apply this concept to a bronzine for biella-manovella. I have considered that in the act of motion are generated inertias that have equal or multiple frequency of the rotation speed of the crank, so at first impact I would have said play between bronzine and crank and interference between bronzine and biella head. then I thought that those inertial forces are usually balanced and there I told myself that rather than making other mental movies maybe it was better to ask who knows more about me!!! What do you think? Thank you all.
