Teo-77
I have a 6m square on the side made by 4 matching plates measuring 1500x6000 thickness 3 mm aisi 304. The plates are combined longitudinally by welding bench. for the whole side I applied a tolerance ± 1/2 it 13, ~1,6 mm every 1000 therefore ± 5 mm. while for the welded side I considered the lamination tolerance - 0.25 + 0.5 of the 1500 format, obtained a long time ago from a mill catalog, thus obtaining a tolerance of -1 + 2 (summatory of the tolerances of the 4 plates). I wanted to know that to give the welds to be added in turn to that of the plates in order to obtain the tolerance on the welded side. I initially thought the usual ± 1/2 it 13 on both sides, then I considered that the 4 sheets from 1500 can become also 6 from 1000, everything depends on what is purchased. Thank you very much in advance
