Cri495 Guest May 15, 2020 #1 and from a week or more that I am trying to create a curve from a sandvik tool directly from their you can download the 3d of the tool precisely but then it turns out all blocked someone and succeeded in the enterprise
Kekkone Guest May 15, 2020 #2 You should put it in normal view and project its edges on the work plane... .
Cri495 Guest May 15, 2020 #3 thanks for the answer I managed now, I took the wrong way using inventor you can do everything with featurecam not without tribulations but you can
