tool scale
  • Thread starter Thread starter luigi9555
luigi9555
Is it me wrong or is it not possible to insert angle steps (in place of the landing to understand us) in a scale to l?
set tools/creation scale 90grade. then in the settings there is the possibility to insert, among other parameters the number of "angular grades" where in the case of 0 it is smooth.
I can't insert a value other than 0 so I always get the landing.
all this with vectoworks 2011 ita.
thanks for any attention
Have you tried the l-stair scale, fixed angle winder? selections in the general tab -> select standard configuration
I do.
I get it now.
the instrument is used to make scales of type "balancé" or French. those that follow the steps during the curve between the ramps.
in this case the tool begins to work when entering high numbers instead of 0 type 5 or more; with 1 or 2 does not perform the calculation of subdivision and returns to 0.
I was convinced that he could split the landing into two or three oblique steps as often used by us in lack of space.. .
Thanks the same.
