tools for armor drawings
  • Thread starter Thread starter Dario1982
Dario1982
Good morning to all, I ask you a tip: what is the best software to integrate with autocad to make armor boards? I work for a Swiss study, and in Swiss it is used "bacad", I don't know if anyone knows it, I'm starting to use it recently, but it's really "woody" as a program, I'm going crazy to make a simple armor of an insole inside a gallery.. In short, I find it not practical, it often makes mistakes, etc. If I had drawn "hand" armor only using autocad at this time I would have already finished. for the future I would like to propose to my company to buy a better tool than this.. based on your experiences, would you know how to indicate good software in this sense? that allows to work quickly and in a practical way.. Thank you so much!
armor of the gallery regularization insole?
I had to make one (we talk about the executive to be sent to ferriera to get the armor produced) and between the inclination of the gallery, changes of the plan of regularization regarding the bottom gallery, and run of the docks inside the gallery, I was forced to create the 3d real of the gallery, cmple of docks and insole, and then "slide" the tunnel every 5m to arm hand section by section.
if there was a soft one doing this: 1) how much should it cost (additive to autocad obviously); 2) what would the experienced designers use?
Difficult programs to make armor. work as long as things are standard, and straight for straight.
As soon as you get out of standard or have irregular figures go into crisis in a moment. and the chaplaints remain to you, not to the producer of soft.
Thank you very much for the answer, crystal. In fact it is a "zwischendecke", a bedside in the cap for the passage of the clean air, as from jpeg attached.
In fact, I realized that as soon as there is a particular form it goes into crisis. the only advantage is the automatic creation of the iron list, but for the rest. .decke.webp
If, as I imagine, the position of that insole is not static compared to the tunnel, but it is parallel to the road floor, you will have a cross section that varies almost continuously.
In fact, 10cm of height is more or less than the gallery (and 10cm are nothing, both for the slope of the track, and for any transversal slopes due to curves, as well as the inevitable errors during the excavation phase) to see it widen or shrink even in a remarkable way. I think with a software you don't get a spider out of the hole.
