toptron 13, how to make it work on windows 7 64???
  • Thread starter Thread starter Plaguebreath
Plaguebreath
I made the move to a new machine equipped with windows 7 at the last and here is the request that I feared the most "but I need to top 13 you can install it?" I started sweating and tried the installation. we are equipped with hasp usb key and already this stinked me.... However finished installation, launch all and boom license error ... I call technical assistance and the answer was "used a partition with xp" of course I can't do it for licensing issues!
already tried but it is a little reliable and quite slow solution in vm. yes the problem is almost certainly due to the compatibility of the hasp with 64 bit drivers
the problem is almost certainly due to the compatibility of the hasp with 64-bit drivers
I just installed a cartographic program in my colleague's win7_64 pc, protected by hasp key, without any problem and without any "addition" of third parties.
you are sure that the logged user is administrator of his own computer..?
I do not doubt that you can install programs with hasp drivers for windows 7, because this installation has not gone well in the cym and especially the assistance says that it is not supported.
uac disabled and admin installation performed automatically, I had already tried obviously ;)
the key is usb and is correctly detected by the other cim9 installed on the machine.
for xp you can do everything but as well you know the separate partition speech is a license violation. I could use xpmode but I wanted to avoid triggering a virtual machine (not exactly free from problems especially with usb peripherals) to do this job.
for xp you can do everything but as well you know the separate partition speech is a violation of the license. I could use xpmode but I wanted to avoid triggering a virtual machine (not exactly free from problems especially with usb peripherals) to do this job.
...I don't understand why...if you use xp partition you can't use other partitions at the same time...you always use one at a time... so the session is always one.. .
different speech if you use virtual machines like vmware but I doubt that you can work with cim13 with a virtual machine,,
on a workstation machine with preinstalled windows 7 64 I cannot have installed xp simultaneously unless I have another license available, this was the reference to license violation. for vm wmware is the same speech, you can use a vm if you have the usage license for it, while the xp mode is a separate issue.
I fear that stinit refers to the cimit license while plaguebreath to that of windows ... :biggrin:
I see it hard to run a 2002 software, no longer supported, on win 7 64bit. :rolleyes:
the solution is to use native winxp.
I thought I wrote it clearly above in fact;) I would not be so negative in installing said software on windows 7, unlike other releases of winzoz gave me great satisfaction.
win 7 is definitely a great know, it is cimit to be problematic ... :biggrin:
with a win 7 32bit hai provato?
In fact: ...it is clear that you have to have all the licenses... However make a virtual machine installation I think it is difficult also for the connection of the various doors... and for the use of a "virtual" video card that would not be enough for those who make graphics. .
on vmware I had installed ubuntu and with that video card (virtual) I didn't even have access to the graphical effects of compz (cubo, etc.)
a win 7 32 on a xeon 8 processors with 8gb ri ram is like blasphemy in church, however I did not try as in az we only have winzoz 7 64bittoli and xp where obviously it works....
I also had your own problem, hasp in cimit 13 will never be detected, there is no verse.
He thinks that last month at a certain point he didn't even get 9 to 32 bits anymore, the 64-bit version worked, 32 from day to day no.
did not detect the hasp, from assistance, various tests, various drivers installed but nothing, only solution formatting and reinstalling the pc and everything returned to fuzionare.
follow
Sorry, it's been a while since your last post.... In the meantime, did anyone manage to solve this? In short, I have to buy a new pc and there's no way to find one with xp.
