pisco
Hello.
I press that they are at the first simulations in ansys 11 and should evaluate the torsion rigidity of a structure (frame in traliccio of hollow section profiles). the design was created in solid edge v20 then exported to ansys and applied the relative constraints and loads on points of interest after generating the mesh. Now I would like to know if it is possible to evaluate the rotation of the structure between the two sections i.e. the cross section and the one where I applied the loads (carichi that generate me a pair).:frown:
starting the simulation of a very simple circular section beam subjected to a torque moment on one end and an interlock in the other I carried out the various simulations, but in evaluating the deformation the program shoots me out all values with a unit measuring m/m
Would someone tell me how to cover those results? :frown:
Thank you in advance
