total length material
  • Thread starter Thread starter vincap85
vincap85
Good morning to all,
in solid edge, precisely in the dft is the possibility to insert in the distinct a column total length that gives me the total value of an equal piece multiplied by its quantity? ?
For example, if I have a tubular 80x40x2 2500mm long that in thesieme repeats more than once, can I have the total length(quantity)? ... thank you for answering me
if you have realized the tubulars using the structure command you have the cutting length of the individual pieces and also the total
in his time I had posted this discussionsimilar to your problem if you use this "not welded" tube with different lengths (magari cut to assembly) and mounted at different points of the axieme as an adjustable part.
otherwise use the structure as Edge says.
the problem arises in quantifying the use of "consumer" materials and cut to the assembly that perhaps do not cost little (at the meter) and of which it is necessary to predict the cost in bom.
the par, in this case, is *a single file* but is mounted "adjustable" in the axieme at various points and with different lengths.
in my case are special seals that cost a lot, and sold in reels.
in any case the problem had not been solved and if you find a solution I am still interested.
