total length of a profile
  • Thread starter Thread starter FIGOR71
when you make it solid, it warns you that "the modification of the separate will cancel the automatic generation blablabla.. . "
therefore means that it can no longer properly recalculate the properties.
if in separate cut you want to see only one voice by type of pipe a solution is:
do not change the folders, but exclude from the separate cut all folders except one by type of pipe; then in the distinct make the property appear total length
Yes, it appears. .
I'll use your method. .
Thank you. .
