transform empty objects into full extruded solids
  • Thread starter Thread starter giuliac
giuliac
Hello everyone,
question:
I have a series of walls already high for test with a certain thickness value.
only that they are all "empty" objects, although the height is correct.
is it possible to transform with some command and few operations all objects simultaneously into solid "full" to obtain the same effect that is obtained with the banal extrusion of a closed polyline?
Thank you in advance whoever comes to my rescue!:finger:
giulia
I mean, you've given a line height and now you want to get solids?
the command Convinsolidation works on:
- thick polyline of uniform width with thickness
- closed polylinees of zero width with thickness
- look thick.
then you could convert all lines into closed polylines with the command _convert polylines with thickness into solids and then with boolean subtract the internal solids from the external one to obtain the thickness of the walls
