transformation into dwg
gtsolid
I turned a .slddrw into a .dwg but I have a number of problems in the cartilage:
- the cartouche recognized by autocad does not include all fields (e.g. file: d_4513_010_000a It's not editable) while I should have access to everyone.
- if I try a workaround by gluing a native 2d cartiglio comes to me in very thick contours (it's in the lower part of the annex).
How can I proceed?
dx key on the table "mophical sheet size", select the cartiglio and (if it is a block) do "explodes block"
in the resulting dwg I have all editable fields (no compilation mask as I would have without explosion) and do not solve the problem of thick edges if amount a third cartilage (I glued it in the lower part:1635162967637.png
thick edges are due to the configuration of the autocad design.
if the entities have a thickness or are placed on a layer with thickness with the active thickness mode you will see the thickness at video; to disable it see the guide di autocad
