transparent walls
  • Thread starter Thread starter kadder
kadder
is it possible in the plant to define a color filling that is transparent?
the problem is that by putting a dwg below and tracing the walls I no longer see the openings
select the linked dwg and in the options bar indicates "first floor" instead of "background"
in the options bar there are no options but only the name of the dwg (I used colleague dwg does not matter to be able to delete it later)
Are there any other possibilities or should I use import dwg?
Then it means that when you connected it you didn't check out the "current view" flag.
