tree cat
  • Thread starter Thread starter emanuele grasso
emanuele grasso
I have a product that contains two products.. in turn these two products contain parts
Is there a way to move parts from one product to another without having to drag them? drag is very uncomfortable when you have multiple parts to move
first select the parts holding ctrl, then for
copy the parts: ctrl-c (copy) ctrl-v (paste)
move the parts: ctrl-x (cut) ctrl-v (glue)
in case you want to use the constraints: menu/mechanical design/assembly design/wins/ paste the components (and choose what makes you comfortable)
in the save menu there is also saving management that allows you to save files in new folders.
but that is not what you want.
then alternatively with drag & drop goes well
I have a product that contains pieces of two other articles, which in turn contain parts of other products.
can you remove all parts without dragging them from the product's other? when you have more components to move, drag is very uncomfortable. gartic phone
capital key and select objects to move.
command size and then paste command into the desired product
of course you lose all the constraints and the contextual associations, they must be rebuilt
