Giacomanu
Good morning to all I need to find the way to make a kind of "rendering".
I find myself in a set example (2 pieces) and I have to make true shading the procedure that I do is this: I select the particular to and "I hire it as part of work", select true shading and give it the property that I want example scraped metal, I do the same thing in the second detail (change the material example yellow plastic) then I go to select the axieme in true shading but the details have taken the property of the second particular
