turning between shoulders
  • Thread starter Thread starter torubychan
I would honestly refuse to do anything with that I don't know how to call it, a design isn't, a sketch isn't even a......
I really find it absurd that a teacher is allowed to give a document similar to a student.
If I were you as first I would remake the design even in 2d with autocad or at the table, I would use the baldassini in order to make a quotation at least decent and I would only deliver the design as a tesin, perhaps your teacher would learn something.
But I understand you have to live there, so pretend that it's a decent document and do what he asks.
Good study.
Bye-bye.
for the choice of tools to work the oton, do I refer to the degree coromant m? I don't understand it so well it's coromant grades
I tried to ask a quote to a company that provides brass rods diam. 100mm and practically costs 5,25 €/kg for a total of about 1500kg (complete to make 200 pcs)...all comes almost 7900€ of only material. Is it not that it is better to work on semi-finished products from fusion as sharin said?
bye torubychan
My name is shiren!!!! ! ! ! ! ! ! ! ! !
if you use a thread you need to use
only one person the lather and perhaps a fixer
if you choose a cast you must commit
the modelling
the foundry
quality control
and the operator at the lathe
are complex choices and you have to see if in the end there are revenues
if there are no specific skills and experiences choose the profile
to return the piece
you have to lock a flank in the spindle
and put on the counterpoint
turning all the outside possible
put on the spindle the sweet bites to the diameter of the already worked flange
rotate the piece and lock it
you work the second flancia and what you failed in the first operation
for decentralized hole
build a shape(hole diameter flaunt on platteau)
the mountains on the independent spindle and prepare it for the value of the outside center
insert a flax in the hole and blocks with dowels placed in the chuck caves
you can also make the hole out of a cnc
but you need barns long enough more a series of probblematics
that would be long to explain
When it comes to the dismissal that was given to you by the injunction
no prob
are quick sketches that usually do
Specifically a hypothetical ray
It's not a scandal.
who knows about prog and processing mecc knows what I'm talking about
Mother my shiren(I apologize for misrepresenting you) how much grace!!! However thank you really for all the indications you gave me, as I had to work the piece I knew already but the hole I did not know minimally how to realize it, and then all the possible problems that you indicated to me surely will make sure that it is wrong really little... well,che tell you if not a heartfelt thank you.. .
with a motorized lathe you can do quietly. . is also a short cycle.we sell them and add them, if you want we can also make you a cycle time..;)cmq based on my experience I would work from bar but it takes a machine with a bar passage quite large. .
ah si...beh maybe a I did a cycle... also because I have to choose in a totally hypothetical way also the type of machine to use for e.g.: 1 Lathe+1fresher rather than a working center(maybe buy the first 2 costs less than buy the working center)
