tutorial visi 17
  • Thread starter Thread starter mytyko74
mytyko74
Hello everyone.. .
Did someone find the tutorials for visi 17 in pdf format?? ?
I couldn't.
They'd be comfortable in English too.
thanks to all
alessandro
I thank mtbnicola for the collaboration but these are totally different from version 17.
the 17 interface was completely changed compared to the previous ones.
I am new to the forum and I am understood here because I am also looking for a manual or tutorial for the above program.
advice?
Hi, I started working in a company where they use it and believe me there's nothing
of pdf or things to learn to use it!!! I was a top user and after seeing how it works I felt like I went back a life!!!
Hello, thank you for the answer.
I started to take a look at visi these days following a little 'guide for the previous version and having some experience with solidworks at first glance seems less intuitive.
Thursday I will have to go to a person who makes injection molds that must choose a software cad.
Why do you say that toptron is better?
That was also the choice.
So if a system is parametric is good and if it is a variant is not good, :rolleyes: if you take a file from the outside you can change it??? where do you have the story that allows you to fix it??? a variable all this does both that it is created internally and that the file is imported, do you have an idea what it means?? ? until a person has these beliefs go a little forward, maybe your job is to make boxes without even a complex surface, otherwise maybe before talking you should also think... .
it is not a polemic my, it is that the work experience perhaps should make you understand and see certain things, if you never take files from outside or work on very simple objects ok
with an agreement:tongue:
If you take a file from the outside, can you change it? ? ? ?
Of course I can change it and do what I want... certain commands of the faces are strong but not for that you have to tell me that it takes a story to change it! ! !
...no I don't make boxes, I make molds, I take jobs from outside and complex mathematicians...
hi monster, I don't want to go through a guru as you defined me because I'm not, I start from your initial concept, that the parametric is better, I think if I can discuss it as much as you want and you have to prove that for the molds it is really better, the visi is perhaps one of the few systems completely integrated and I repeat completely, where you can get to the study of the behaviour of the materials, now, I don't want to look a part, but the work, but the reality is that the work.
visi is absolutely not the best, it is of a system of medium band like toptron, where it does not seem less powerful, it is simply different from others, its modules dedicated to molds, mould and progress, are parametric just because that part can be interesting, but only that, you know? ?
I'd like to be "friend" and exchange opinions with you interesting, okay? ?
Greetings:
I don't know what to answer, maybe I see obsolete in visi as a program structure! I should try to make some sticks with real and see how the commands are used. Okay, I'll keep you informed about the development. . .
hi guys, sorry the resume... did someone manage to get hold of some manual/tutorial of version 17 of visi cad?? pdf, doc, video...anything I would do especially comfortable.. .
Thank you very much!
I got something on the manuals. email me on a private message and see if I can send you something.
hello guys, sorry for the up, but does anyone have any guides/tutorial or anything to be able to turn me on visi from release 17 onwards?? I would be really useful... thank you so much in advance! !
