tweak and double click
graziano-g
I realized a sketch that followed some work at the end of which I realized that one of the shares of the starting sketch was wrong.
I opened the sketch for the modification of the quota concerned but I found the following problems, resolved:
selecting the quota this is highlighted but I can't change it i.e. you don't open the window for editing.
I canceled the quota so I reset it, I closed the sketch and everything was updated.
then I remade the test by selecting the quota with the selection rectangle to highlight it and holding ctrl + double click opened the box for editing, okay.
is that normal, is there an exact procedure beyond these?
is it possible to set the speed of the double click autocad type where a quick clik makes me appear the context menu at the operation and a quicker click has the function of sending?
In this case I would need to set the double-click speed with a range greater than the few milliseconds set by default.
inventor 2015 pro, file part not yet saved, can it depend on that?
Hello, thank you.
