Mattymecc
hello to all, I should realize the project of a two-stage parallel axle reducer following these indications:
1) the driving machine is an internal combustion engine, of 90kw power, which at a wheel rate of 2250 rpm
2) the machine operated, on a regimen, rotates to 375 rpm and is not subject to overload
3) the connection of the reducer to the drive machine must be carried out through a hard joint
4) the connection of the reducer to the user must be carried out through a grooved shaft
5) toothed wheels must be to helical teeth and should be designed with the formulas of lewis and hertz, if possible verify them according to norm uni 8862 through the tables
6) Trees must be checked statically and fatigued
7) Dissolve the bearings suitable for longer than 5000h
I would need your help because I am making this project for another person and at school I have not yet dealt with fatigue testing, in particular I have difficulty in verifying the sections weakened by the offices of the tabs, do I have to combine the effect of carving? What diameter do I consider? the outer one or the outer one minus twice the depth of the quarry?
I thought I'd build one-piece pins with cementing steel trees, while the two wheels build them in reclaim steel. Is that a valid idea? today I will begin to make some calculations and tomorrow I will posterior you the size of the wheels. thanks in advance.
