Brick
Hi, I'm new in this forum.
I am a student of mechanical ing engaged with the simulation of a darrieus turbine.
my work starts from a simulation already carried out in another terminal. when, however, I re-initialize the parameters (but even if I don't) and start the iterations, it appears:
error: sopenoutputfile: unable to open file for output
error object: "~/documents/text/percival/calculum/cd-history"
this folder is not present in my pc; the error persists even if I create the path in it indicated.
I naturally tried to set up file-write-autosave... inserting the folder and the file name where I want the steps of the simulation to be stored, but nothing changes.
It is important to emphasize that the same type of error appears even if I start a new simulation based on a new mesh created by me.
It is as if there was a upstream setting where I have to set the correct path, for example in a fantomatic "general options" menu that I couldn't find.
Thank you in advance.
