unblocking/locking automatic axial bond cylindrical parts
  • Thread starter Thread starter blakhaTTT
blakhaTTT
Good morning to all,
I have been using for a couple of months solidedge now and I wondered, is there an automatic possibility to unlock/block the rotations at the same time of all the cylindrical parts present in a set?
for example of all the vines.
I'm talking, maybe it was obvious to act on all ties of axiality.
If anyone can help me.
Thank you in advance.
is not clear to me what you would like to do: in a group to go to block all the axial constraints present in the same?
If so, the risk that you find then with contrasting constraints is very high.
if your problem is focused on the screws, you can lock the first and then store the bond for all the others you will enter.
Hello, thank you for the answer first.
so go to block the rotation options already present in the axial bond and the details present in the same together. then the ones I need to unlock the unlocks manually in case. Thank you.
Hi, I just tried it and I'd say it goes very close to the solution of my problem.
Thank you, I hope to return in the future. You're great.
